Using an existing control definition
To include a previously defined control in a new item or control definition:
- Open the form in which you want to include the control.
- Locate the item or control in which you want to include a previously defined control, and highlight it.
- Open the appropriate control tree in the Trial Objects window.
- Drag the control you want to include onto the highlighted control in the Form definition window.
