Navigating in the Element Editor window
To navigate to a specific element, type the first few letters of the element. The elements list scrolls to the first element whose name begins with that string. After a short pause (less than two seconds), you can type another search string.
Note: This feature is available only when the cursor is not focused on a cell in an element definition row. If you attempt to navigate by typing when you are editing a cell in an element definition, the typing overwrites the contents of the cell. To prevent this, press Esc before typing to navigate.
