Printing the annotated trial design
There are two methods of printing annotated CRFs within a trial:
- Printing the form actively displayed in the Form Editor window.
- Printing all forms defined for the trial.
If your browser is Internet Explorer, you can use the following browser setting to print the annotated trial design with shaded heading bars, as it appears online:
- Select Tools > Internet Options from the Browser menu bar.
- In the Internet Options dialog box, click the Advanced tab.
- In the Printing section, select Print background colors and images.
- Click OK.
If you do not select this setting, the annotated trial design prints with no shading.
