Printing all forms in a trial
When you select File > Annotated Trial Design, the Annotated Design window opens in the Trial Design workspace, listing the full annotated trial design. This listing is generated with the features selected in the Annotated CRF Settings dialog box.
To print the entire file, or any number of virtual pages, select File > Print.
The order of the listing, if all features are selected, is as follows:
- Cover page
- Time and Events Schedule
- CRFs. The order of CRFs is determined by the selections in the Annotated CRF Settings dialog box. You can order forms as they occur in the Time and Events Schedule or alphabetically by form title. The following listings and tables are displayed after each CRF:
- Design note lists
- Unit lists
- Element lists
- Data mapping tables
- Electronic signature affidavits
Each printed form starts a new page and its supporting information (pulldown list tables, data mapping tables, etc.) prints immediately afterwards. Aside from each form beginning on a new page, you cannot control or specify page breaks.
