Setting up a CDD
Setting up a CDD involves the following steps:
- Design CDD data mappings and define them through the InForm Architect application.
Note: After defining CDD data mappings you must install them in the InForm application database by saving them in the InForm Architect application with the Install MedML When Saving option enabled or by using the MedML Installer utility.
- Create a CDD using the InForm application PFAdmin command.
- Enable CDD processing using the PFAdmin command in the InForm application.
Note: This section describes how to define and maintain CDD mapping definitions in the InForm Architect application. For information on creating the CDD database and Oracle 9i user, creating the ODBC connection for a CDD, and enabling CDD processing in the InForm application, see Installation and Configuration Guide.
