Auto-generating CDD mappings
The preferred and easiest method for creating CDD mappings is to use the InForm Architect application auto-generate feature. To auto-generate CDD data mappings for a complete trial:
- Start the InForm Architect application.
- Open the trial for which you will create CDD data mappings.
- In the Trial Objects tree, right click Data Mappings and select Create CDD from the pop-up menu to display the Create Data Mappings dialog.
- In the Create Data Mappings dialog box, select Auto-Generated. To generate column names consisting of the RefNames of controls, select Use Control as Default Column Name.
- Click OK. The InForm Architect application produces data mappings for each object in the trial.
