Control path mapping properties
The following table describes the properties of a Clintrial control path mapping definition.
Property |
Definition |
Control Path |
RefName path of the control path mapping. READ-ONLY. |
BlockKey Value |
Value of the Clintrial block key. If you specify this value, it overrides the visit RefName as the block key. For more information, see Using page keys and block keys. OPTIONAL. |
PageKey Value |
Value of the Clintrial page key. If you specify this value, it overrides the form RefName as the page key. For more information, see Using page keys and block keys. OPTIONAL. |
Subset Value |
Value the item takes if it is the subset key for subset page sections based on the panel. For more information, see Implementing Clintrial subsets. OPTIONAL. |
