Mapping data to the Clintrial software
To pass data to a Clintrial database, you must create mapping definitions that show how InForm trial objects correspond to Clintrial objects. The InForm Architect application can generate mappings automatically for an entire trial, or you can create or modify them manually for individual objects.
