Updating a CONTEXT panel item
To update a CONTEXT panel item:
- Start the InForm Architect application.
- Open the trial containing the mapping definition for the CONTEXT panel item you want to update.
- In the Trial Objects window, expand the Data Mappings node.
- Double-click the mapping definition.
The Data Mappings window opens in the Design Workspace.
- Expand the ContextPanel node, and select the item to update.
The properties of the CONTEXT panel item appear in the Properties window.
- Change the item properties as desired.
- Make sure that the Strict MedML Checking button is selected.
- Select File > Save Component or File > Save Component As, and specify where you want to save the updated mapping definition.
The InForm Architect application saves the mapping definition in the specified location.
