Modifying Clintrial Item Order in a panel
In a set of mappings, the order of items within a form determines the default autogenerated Item Order of each item in the corresponding Clintrial panel. Item Order defines the order of the item in Clintrial reports and in the default page section layout.
You can change the order of items within a Panel mapping, by dragging and dropping the Item nodes as desired in the Data Mappings window. This changes the Item Order of the items in the Clintrial panel.
The Item Order in Clintrial software is determined when CIS first creates the item in the Clintrial protocol; CIS does not change Item Order after it has been created. Therefore, if you want to change the order through the data mappings created in the InForm application, you must do it before the item mapping is synchronized to the Clintrial software for the first time. Usually, this is the first time you synchronize the trial to the Clintrial software. (You can still change the order by using the Design module of the Clintrial software.)
