Definitions of Central Coding mapping terms
The following table defines terms you should understand when developing Central Coding mapping definitions:
Term |
Definition |
Central Coding |
Oracle application used to identify and apply appropriate codes to verbatim items. |
code target |
Coding dictionary construct that helps to classify data to be coded. Also, a corresponding form control holding data that has been coded. |
context item |
Coding dictionary construct that helps to classify context information for data to be coded. Also, a corresponding form control that provides additional information to enable coding of a verbatim. The WHODD dictionary uses context items to provide the following information:
dictionary |
Standard thesaurus containing terminology used for coding. Central Coding supports the MedDRA and WHODD dictionaries. |
InForm Adapter |
Oracle application used to transfer verbatim and coded data between the InForm application and Central Coding. |
MedDRA |
Medical Dictionary for Drug Regulatory Activities—Standard thesaurus containing terminology applicable to all phases of drug development and to the health effects of devices. |
verbatim |
Form item holding data to be coded. |
verbatim type |
Specific type of verbatim defined in a coding dictionary. The following verbatim types are defined for the dictionaries supported by Central Coding:
WHODD |
World Health Organization Drug Dictionary—Standard thesaurus containing terminology about drugs. |
