Expanding and collapsing the view of mappings
You can expand or collapse all nodes in the Data Mapping window at once. Right-click in the window and select one of the right-click menu options.
The following table describes the options for expanding the collapsing the view of mappings:
Command |
Resulting view in Data Mappings window |
Collapse All |
All nodes collapse so that only the mapping object node is visible |
Expand All |
All nodes expand so that visits, verbatims, targets, and context items are visible |
Collapse Visits |
Visit nodes collapse so that only visits are visible |
Expand Visits |
Visit nodes expand so that visits and verbatims are visible |
