Updating a data mapping definition
To update any component of a data mapping definition:
- Open the Data Mappings window for the data mapping definition you want to edit by double-clicking its icon in the Trial Objects window.
- Expand the mapping definition nodes as necessary to expose the component you want to update.
- Select the component.
- In the Properties window, edit the properties you want to change.
