Removing a mapping definition
You can disable a mapping definition by using the Active property of the definition. When a mapping definition is disabled, it is invisible in the InForm Architect application.
To disable a mapping definition:
- In the Trial Objects window, double-click the icon for the mapping definition to open the definition in the Data Mappings window.
- In the Properties window, change the value of the Active property to Inactive.
- Save the mapping definition and install it by doing one of the following:
- Save the definition with the Install MedML When Saving option enabled.
- Install the definition with the MedML Installer utility.
The mapping definition disappears from the Trial Objects window. If the Data Mappings window is open at the time you install the new definition, it closes.
