About rules
A rule is a piece of code that runs in the context of one or more specific items on a form. You code rule scripts with Visual Basic Script (VBScript) that refer to the script files, and associate the rule definitions with the items against which they run. This section provides an overview of rule and event processing, describes the types of rules the InForm Architect application supports, and discusses the concept of rule contexts.
