Generic form context
A Generic Form context associates the rule with an item in a form in every instance of the form in the trial. For example, you can associate a rule with the body temperature item on the Vital Signs form using a Generic Form context. Each time that data is entered or updated in the body temperature item on the Vital Signs form, the rule runs, regardless of the visit. If the body temperature item is used on a form other than Vital Signs, the rule is not associated with it.
