Conversion rules
Conversion rule scripts specify the factor to use when converting units between the entered value of a data item and the normalized value, which is the value of the item stored in the database after conversion. A typical conversion rule, which is associated with a unit definition, loads the Result property of the Data object with the result of a conversion calculation.
