Reordering visits in a trial
To change the order in which a visit occurs:
- Open the Protocol Editor window.
- Drag the icon of the visit you want to move and drop it onto the visit that you want it to follow. To change a visit to the first visit of a trial, drop the icon onto the trial name.
Note: You can reorder only regular visits. The order of screening, enrollment, and monitoring visits is predefined, and a trial can have only one of each of these visit types. Dynamic visit order is determined by the sequence in which you create each visit. However, you can change a regular visit to dynamic or a dynamic visit to regular by dragging and dropping the visit onto the appropriate visit type.
