Examples of documentation definition XML files
The files associated with the DOCUMENTATION definitions are available in the InForm user interface after you:
- Load the DOCUMENTATION definitions into the trial database using the MedML Installer utility. For more information, see the Utilities Guide.
- Associate the DOCUMENTATION definitions with a study version. For more information, see Trial documentation and study versions.
