CRF Help documentation definition
This example illustrates the definitions used to load the files that define CRF Help into the trial database. The files included with this set of DOCUMENTATION definitions appear in the Documentation window when a user clicks the Documentation button and then the CRF Help tab in the InForm user interface.
<MEDMLDATA>
<DOCUMENTATION REFNAME="Study"
DOCNAME="CRF Help"
DOCTYPE="BOOKMARKFAQDOC"
HELPTEXT="Click here to view information on completing CRFs"
TOC=".\StudyGuide\SG_TOC.htm"
TOCLINKS="10">
<DOCBODY REFNAME="SCREENHELP" FILENAME=".\StudyGuide\ScreeningLog.htm"/>
<DOCBODY REFNAME="ELIGHELP" FILENAME=".\StudyGuide\Eligibility.htm"/>
<DOCBODY REFNAME="SSHELP" FILENAME=".\StudyGuide\Signs_Symptoms.htm"/>
<DOCBODY REFNAME="DEMHELP" FILENAME=".\StudyGuide\Demographics.htm"/>
<DOCBODY REFNAME="VSHELP" FILENAME=".\StudyGuide\VitalSigns_BP.htm"/>
<DOCBODY REFNAME="CHESTHELP" FILENAME=".\StudyGuide\ECG_Chest_XRay.htm"/>
<DOCBODY REFNAME="PEHELP" FILENAME=".\StudyGuide\Physical_Exam.htm"/>
<DOCBODY REFNAME="PEW8HELP" FILENAME=".\StudyGuide\Week8_Physical_Exam.htm"/>
<DOCBODY REFNAME="CMHELP" FILENAME=".\StudyGuide\Con_Meds.htm"/>
<DOCBODY REFNAME="SCHELP" FILENAME=".\StudyGuide\Study_Completion.htm"/>
</DOCUMENTATION>
</MEDMLDATA>
