Creating a Rule Help placeholder
For each item that has a rule for which rule help has been created, create an unordered list that contains no list items but contains the following text:
!R item_REFNAMEPath!
where item_REFNAMEPath is the REFNAMEPath used to address the data item. For example, if the rule is on the Weight item of the Demographics form, code the Rule Help placeholder as follows:
<ul>!R Visit1:DEM:DEM:WEIGHT!</ul>
The Rule Help placeholder should follow the help text on the data item and precede the FAQ placeholder. See Example: Creating a Rule Help placeholder.
