Learning with sample trials
Along with the Base trial definitions, the InForm application installation enables you to load several sample trials, each containing a complete set of forms for a hypothetical trial. You can use the sample trials for training, familiarization with the InForm application, and for performing installation qualification.
The sample trials provided with the InForm application are:
- PFST—Depression trial with trial components that illustrate InForm application features such as dynamic forms and visits, associated forms, and repeating forms. To install this trial automatically, click Start > Programs > Oracle Health Science > InForm 4.6.5 > Install Sample Trial for Oracle.
- PFST45—Depression trial with the product features of PFST45 and sample clinical data. To install this trial automatically, click Start > Programs > Oracle Health Science > InForm 4.6.5 > Install Sample Trial 4.5 for Oracle.
PFST45 includes a set of clinical data that you can load and use to test the reports delivered with the InForm Reporting and Analysis module and to develop and test custom reports. This data is available as an Oracle database extract. For information about how to load the clinical data into the PFST45 trial database, see Installation and Configuration Guide.
This trial is recommended as the best sample to investigate initially. For information about how to load the clinical data into the PFST45 trial database, see Installation and Configuration Guide.
When you are ready to load the components for a true trial, you can remove any sample trials by using the pfadmin utility, as described in Installation and Configuration Guide.
