Edit checks
MedML enables you to create automated edit checks on CRF items. In the InForm application and the InForm Architect application, these checks are known as rules. You can create multiple rules on a single item, and you can create rules and calculations in which the outcome of the rule or calculation depends on the value of one or more data items on the same or other forms. When you design rules, bear in mind that each of the following choices can affect performance negatively:
- Multiple rules on an item.
- Many rules on a form.
- Multiple dependencies on items in the same or other forms.
