Client-side and server-side edit checks
The InForm application enables client-side or server-side edit checks:
- Client-side edit checks are performed when a user exits a control, before submission of data. You can use this facility to check for conformance with minimum and maximum value ranges or to ensure that all parts of a multiple-control item (for example, a date field where all parts of the date are required) are filled in.
- Server-side edit checks are performed when a user submits data. Any edit checks that involve comparisons, calculations, checks for the existence of entered data, or specific data properties other than minimum or maximum values require processing on the server.
