Planning data mappings
The InForm application allows you to map the data stored in an InForm application trial database to external systems where you can use third-party analytical tools. The InForm application supports mapping to the following external data entities:
- Customer-Defined Database
- Clintrial software database
- Oracle Clinical software
Additionally, you can create mappings between data points in an InForm application trial so that you can export data to be processed by an external coding tool and then reimport it after coding to the target controls specified in the mappings.
