Dragging and dropping form components
The Form editor window enables you to set up a form definition quickly by dragging form components from the Object Palette toolbar or the Trial Objects window into the Form editor window, and dropping them into the appropriate location in the Form structure. The Object Palette toolbar gives you access to templates for creating new form components. The Trial Objects window contains definitions of existing form components. For further information, see Defining Forms.
