Displaying and hiding toolbars
By default, all toolbars are visible when you start the InForm Architect application. To hide a toolbar, use either of the following methods:
- Select View > Toolbars; then click to clear the selection of the toolbar you want to hide.
- Click anywhere in the toolbar section of the main window with the right mouse button. In the pop-up menu that appears, click to clear the selection of the toolbar you want to hide.
To restore the display of a hidden toolbar, repeat the above instructions, but select the toolbar you want to display.
