Restrictions
When you copy or duplicate form components, observe the following restrictions:
- You cannot paste or drag copied or duplicated components into a location that would create more than five levels of nesting.
- You cannot paste hierarchical components such as groups, radio groups, or check box groups into a location that would create a circular definition between parent and child components. For example, in the following structure:
Group1
Radio Group1
Checkbox Group 1
You cannot copy Group1 and paste it as a child component under Checkbox Group1.
