Saving a copy of the contents of an editor window
You can save a copy of the XML file for a trial definition or a specific form in a specified directory. To save a copy:
- Select File > Save Component or Save Component As. As a shortcut, you can click the Save button
on the Main toolbar. - In the Save Copy As dialog box, specify the directory and file where you want to save the trial definition XML.
- Click Save.
If the Trial Design window is active when you save, the InForm Architect application generates an XML file containing the definition of the trial. If a form window is active, the InForm Architect application generates an XML file containing the definition of the form.
