Installing trial component definitions in the database
When you save trial component definitions by using any of the methods described in this section, the InForm Architect application generates XML files and response files that you can process with the MedML Installer to load the definitions into the InForm application database. To load trial component definitions into the database, use either of the following methods:
- Use the MedML Installer to process the response file containing the names of all the component XML files you want to load.
- Click the Install MedML When Saving button
on the Settings toolbar. When this toggle button is depressed, the InForm Architect application generates the component XML files and response files appropriate to the save option you choose and also calls the MedML Installer to load the generated files into the database.
