Moving a trial into production
When your trial design is complete, you can install it in a test production or production environment. Before you move a trial from one environment to another, ensure that:
- The InForm application is installed on the production or test production server.
- A complete set of trial components is saved as MedML. When saving from the InForm Architect application:
- Select Strict MedML Checking.
- Deselect Install MedML When Saving.
To install a trial in a production or test production environment:
- Save all trial components as MedML on the production machine.
- Set up a new trial on the production server using the pfadmin command. For information about pfadmin, see Installation and Configuration Guide.
- Install the basic trial components in the production trial using the dbsetup command. For information about dbsetup, see Installation and Configuration Guide.
- Install the saved trial components in the production trial using the MedML Installer utility. For information about the MedML Installer, see InForm Utilities Guide.
