Implementing an alternate form
To implement an alternate version of a form:
- Use the appropriate form definition components to create, save, and install a form that includes the new items to collect.
Note: You can do this step by using the InForm Architect application. For the remaining steps, you must manually create an XML file that defines a revised trial definition.
- Include the alternate form in a StudyVersion definition by using the ALTREFNAME attribute of the FORMREF tag that associated the original form definition with a VISIT FormSet.
- Update the StudyVersion by changing the VERSIONDESCRIPTION attribute.
- Load the new StudyVersion with the MedML Installer tool.
