Coding dictionary XML
The following table lists the MedML components that identify a coding dictionary:
MedML component |
Description |
Attributes |
DICTIONARY |
Identifies the coding dictionary. Each DICTIONARY tag must have at least one CODETARGET child element and can have one or more CONTEXTITEM and VERBATIMTYPE child elements |
All are REQUIRED. and together uniquely identify a dictionary. |
CODETARGET |
Identifies a specific code target defined in the dictionary. |
NAME—Name of the code target, for example, ATC 1.CODE. REQUIRED.. |
CONTEXTITEM |
Identifies a specific context item defined in the dictionary. |
NAME—Name of the context item, for example, Route Of Administration, Indication. REQUIRED.. |
VERBATIMTYPE |
Identifies a specific type of verbatim defined in the dictionary. VERBATIMTYPE corresponds to item type in Central Coding. |
NAME—Type of verbatim item, for example, AE, DISEASE, LABDATA, MEDPROD. AE, DISEASE, and LABDATA are valid verbatim types for the MedDRA dictionary. MEDPROD is a valid verbatim type for the WHODD dictionary. REQUIRED.. |
