Dictionary XML updates
When you install a valid updated definition of a coding dictionary in the InForm application database, the InForm application:
- Creates a new revision of the dictionary definition if a dictionary with the same the type, version, and culture exists in the database.
- Checks whether any code targets or context items in the current dictionary definition do not exist in the new definition. If so:
- The InForm application checks all coding mappings for references to the obsolete code targets or context items and removes code target and context item control paths that are no longer part of the dictionary.
- For each removed code target or context item control path, the MedML Installer displays a warning indicating the removal.
