Defining a common form
To define a common CRF:
- Create a form definition for capturing cumulative data by using the InForm Architect application. The following formats work well for common CRFs:
- Itemset format, in which data are displayed in rows consisting of associated, repeated items.
- Repeating form format, in which multiple instances of the same data points can be collected in the same form in the same visit.
- In the form definition, specify True as the value of the Common Form property.
