Defining a HelpLink component
To define a HelpLink component:
- Use the <HELPLINK/> tag.
- Use the DOCREFNAME tag to specify the RefName of the Document component representing CRF Help.
- Use the BODYREFNAME tag to specify the RefName of the DocBody component that represents the CRF Help file where the bookmark occurs.
- Optionally, use the BOOKMARK tag to specify the bookmark you want displayed at the top of the window when a user clicks a CRF link in an item. If you do not specify a BOOKMARK tag, the CRF Help file opens to the top of the file, and users must scroll to the specific item definitions they want.
