Creating a dynamic form in a visit
To create a dynamic form definition in a specific visit:
- Create the form that will appear in the visit.
- Add the form to the visit in the Protocol Editor.
- In the Protocol Editor, select the form.
- In the Properties window that is visible when you select the form in the Protocol Editor, set the value of the Dynamic property to True.
Note: The dynamic aspect of a form is a property of association with a visit, not of the form itself. Therefore, you can use the same form as a regular CRF in one visit and a dynamic CRF in another.
