Monitoring forms
Monitoring forms are custom forms that are available in the InForm application when a user clicks the Monitor navigation button. MedML supports the creation of the following types of Monitoring forms:
- Visit Report—A form that enables a CRA to report on a visit to a specific site. To accommodate the reporting of multiple visits, you can set up a Visit Report as a repeating Form.
- Regulatory Document Checklist—A form that enables a CRA to record a site’s compliance with documentation requirements such as the availability of current trial documents and regulatory documents such as the trial protocol, IRB approvals, and electronic signature reporting documentation.
Note: Even if you do not plan to collect visit report or regulatory documentation data, you should create blank forms as placeholders.
