Creating a Regulatory Document Checklist
To create a Regulatory Document Checklist:
- Using the appropriate MedML components, define a form that captures the data you want to include in the Regulatory Document Checklist.
- In the form definition, specify REGDOC as the value of the TYPE attribute.
- Include the form in a visit definition that has the following characteristics:
- The value of the visit TYPE attribute is MONITOR.
- The value of the UNSCHEDULED attribute is True.
Note: These instructions describe how to set up a Regulatory Document Checklist that is not repeating. To create a repeating Regulatory Document Checklist, follow the instructions for creating a Visit Report, substituting REGDOC as the value of the Form TYPE attribute.
