Customizing the patient record transfer affidavit
To customize the patient record transfer affidavit:
- Copy the sysform_PatientSiteChange.xml file in the \InForm\XMLBase folder of the InForm application installation to the \Custom folder for your trial. Do not make changes directly in the system_PatientSiteChange.xml file.
- Edit the affidavit portion of the <FORM> tag in the copy of the sysform_PatientSiteChange.xml file. Within the affidavit text, you can use HTML characters for formatting and highlighting.
- Add the edited copy of the file to the .rsp file you use to load your trial metadata into the trial database.
