Associating a form with a signature group
You can associate CRFs and Case Books with signature groups. To associate a CRF or Case Book with a signature group, create XML for each form that requires an authorized signature, using the SIGNCRF MedML tag.
One form represents the Case Book for signature purposes. To designate a CRF as the Case Book signing form, specify its RefName as the FORMREFNAME in the SIGNCRF tag, and specify True as the value of the FINALCRF attribute.
The SIGNCRF tag has the following syntax:
<SIGNCRF
SIGNATUREGROUPNAME="name"
FORMREFNAME="name"
[RESETFORMSTATE="TRUE|FALSE"]
[INVALIDATIONLEVEL="USER|GROUP"]
[FINALCRF="TRUE|FALSE"]/>
The following table describes the attributes of the SIGNCRF tag:
Attribute |
Description |
SIGNATUREGROUPNAME |
Identifies the authorized signature group. The signature group must have already been defined by a SIGNATUREGROUP tag. REQUIRED.. |
FORMREFNAME |
Specifies the RefName of the CRF. The form must have already been defined in the system. Note that screening and enrollment forms cannot be signed. REQUIRED.. |
RESETFORMSTATE |
Specifies the policy for handling already-signed forms when a new signature group is added. Values are:
OPTIONAL. |
INVALIDATIONLEVEL |
Specifies whether a signature should be invalidated when a data item is imported through Autocode or Central Coding processing after the form has been signed. Values are:
OPTIONAL. If you do not specify the INVALIDATIONLEVEL attribute, the InForm application invalidates the signature whenever the form is edited, either directly or by import. For more information, see Signature invalidation. |
FINALCRF |
Indicates whether the form specified in the FORMREFNAME attribute represents the entire Case Book for signing purposes. Note the following restrictions on the CRF designated as the Case Book signing form:
Values are:
OPTIONAL. |
