Updating the STUDYVERSIONSITE tag
To update a STUDYVERSIONSITE tag:
- In a text editor, display the study version XML file that you want to update. The syntax of the tag is shown below:
<STUDYVERSIONSITE
VERSIONDESCRIPTION="text"
[SITENAME="name"]
[SITEMNEMONIC="name"]
[ACCEPTDATE="date"]/> - The VERSIONDESCRIPTION key identifies the version. Update the key to the same value you used in the corresponding STUDYVERSION tag.
- Either SITENAME or a SITEMNEMONIC attribute is required to identify the site.
- Optionally, set the value of the ACCEPTDATE attribute to the date of IRB approval. Note that this date is for documentation purposes only. The actual date that a site moves to a new StudyVersion is the date that the StudyVersionSite component for the site is revised in the database.
- Use the MedML Installer to process the STUDYVERSIONSITE tag when the site is ready to use the new version.
