Metadata Update report
When you update a section or item definition by using the UPDATE_FORM_SECTION or UPDATE_SECTION_ITEM tags, you can generate a report that summarizes the updates you have made and indicates whether the updates involve items in which patient data has previously been entered. This report, called the Metadata Update report, is available in the Reports module of the InForm application. To view the report, you must be in a rights group that includes the Admin Reports right.
For detailed information about the Metadata Update report, see the InForm application online Help. The following figure illustrates the Metadata Update report.
