Client computers—Microsoft Windows
The InForm 4.6.6 client was validated using Microsoft Windows 10. For more information, see the Installation and Configuration Guide.
Browsers |
Display resolution |
Microsoft Excel |
A version compatible with your operating system is required to view reports exported from the Data Viewer or Cognos Reporting. |
Adobe Acrobat |
Adobe Acrobat Reader DC or higher to view reports in PDF format. |
