Comments
Comments
Report element |
Description |
Comment Date |
Data type: Date Description: The date when the comment was entered in the InForm application. Data source: Entered in the InForm application. |
Comment Text |
Data type: String Description: The comment text (limited to 255 characters). Data source: Replicated from the InForm transactional database to the Reporting and Analysis database. |
Comment Type |
Data type: Text Description: The comment type. Valid values are:
Data source: Derived for the report; not stored in the Reporting and Analysis database. Database value decoded for display. |
Comment Count |
Data type: Numeric Description: The number of comments. How calculated: Counts all item-level and form-level comments. Data source: Derived and stored in the Reporting and Analysis database. |
Item Count
Data type: Numeric Description: The number of item-level comments only. Item comments can be manually entered by an InForm user or automatically generated when an item is marked Incomplete. How calculated: Counts item-level comments only. Does not count form-level comments. Data source: Derived and stored in the Reporting and Analysis database. |
Form Count |
Data type: Numeric Description: The number of form-level comments only. How calculated: Counts form-level comments only. Does not count item-level comments. Data source: Derived and stored in the Reporting and Analysis database. |
