Sites
Note: If an optional item is left blank in the InForm application, data does not appear in reports that contain the report element for that item.
Sites-related report elements
Report element |
Description |
Site Name |
Data type: String Description: The name of the site, as entered in the InForm Administration interface. Data source: Replicated from the InForm transactional database to the Reporting and Analysis database. |
Site Mnemonic |
Data type: String Description: An abbreviation that identifies a site, as entered in the InForm Administration interface. Data source: Replicated from the InForm transactional database to the Reporting and Analysis database. |
Address 1 |
Data type: String Description: First line of the site address, as entered in the InForm Administration interface. Data source: Replicated from the InForm transactional database to the Reporting and Analysis database. |
Address 2 |
Data type: String Description: Second line of the site address, as entered in the InForm Administration interface. Data source: Replicated from the InForm transactional database to the Reporting and Analysis database. |
City |
Data type: String Description: The city in which a site is located, as entered in the InForm Administration interface. Data source: Replicated from the InForm transactional database to the Reporting and Analysis database. |
State/Province |
Data type: String Description: The state or province in which the site is located, as entered in the InForm Administration interface. Data source: Replicated from the InForm transactional database to the Reporting and Analysis database. |
Country |
Data type: String Description: The country in which a site is located, as entered in the InForm Administration interface. Data source: Replicated from the InForm transactional database to the Reporting and Analysis database. |
Postal Code |
Data type: String Description: The postal code for the site address, as entered in the InForm Administration interface. Data source: Replicated from the InForm transactional database to the Reporting and Analysis database. |
Phone |
Data type: String Description: The primary telephone number for the study site, as entered in the InForm Administration interface. Data source: Replicated from the InForm transactional database to the Reporting and Analysis database. |
Alt Phone |
Data type: String Description: The site secondary telephone number, as entered in the InForm Administration interface. Data source: Replicated from the InForm transactional database to the Reporting and Analysis database. |
Fax |
Data type: String Description: The fax number for a study site, as entered in the InForm Administration interface. Data source: Replicated from the InForm transactional database to the Reporting and Analysis database. |
Data type: String Description: The email address for a site contact, as entered in the InForm Administration interface. Data source: Replicated from the InForm transactional database to the Reporting and Analysis database. |
Time Zone |
Data type: String Description: The time zone in which a study site is located, as entered in the InForm Administration interface. Data source: Replicated from the InForm transactional database to the Reporting and Analysis database. |
Date Format |
Data type: Numeric Description: The format used for all references to dates for the site. Valid values are:
Site Activation Date |
Data type: Date/Time Description: The projected date for the activation of the study by the site. It does not necessarily reflect the actual date on which the activation occurs. Date type: May be specified in study design code. If not, this is a system date. |
Current Study Version |
Data type: String Description: Displays a description of the most current study version, as specified in the study design code. Many study designers use this field to indicate study version iteration. For example, 2 indicates the second version of the study. The value may also be a text description for the study version. Data source: Replicated from the InForm transactional database to the Reporting and Analysis database. |
Current Site Acceptance Date |
Data type: Date/Time Description: The date on which the site was assigned to the current study version. Date type: May be specified in study design code. If not, this is a system date. The date that appears here depends on how the site was associated with the current study version:
