Items: Item Status Counts
Items: Item Status Counts return totals of items (relative to the number of subjects) in various states.
Items: Item Status Counts report elements
Report element |
Description |
Item Count |
Data type: Numeric Description: The total number of items, relative to the subjects participating in the study. How calculated: Counts each item for each subject if it contains (or ever has contained) clinical data. Data source: Derived and stored in the Reporting and Analysis database. |
Empty |
Data type: Numeric Description: The total number of items that currently have no data. How calculated: Counts items for each subject if both of the following are true:
Source Verified |
Data type: Numeric Description: The total number of items with a current status of Verified. How calculated: Counts items that have a current status of Verified. Data source: Replicated from the InForm transactional database to the Reporting and Analysis database. |
Marked Incomplete |
Data type: Numeric Description: The total number of items that are currently marked Incomplete. How calculated: Counts items that have comments with an Incomplete Reason of Not Done, Not Applicable, or Unknown. Data source: Replicated from the InForm transactional database to the Reporting and Analysis database. |
Deleted |
Data type: Numeric Description: The total number of items that have been deleted in the InForm application. How calculated: Counts items that are add-entry items and have been removed. Data source: Replicated from the InForm transactional database to the Reporting and Analysis database. |
Has Item Comment |
Data type: Numeric Description: The total number of items that have had an item-level comment associated with them. How calculated: Counts items that:
Has Query |
Data type: Numeric Description: The total number of items that have at least one associated open query. How calculated: Counts items that have at least one associated open query. Does not count items whose only associated query is a candidate query. Data source: Derived and stored in the Reporting and Analysis database. |
Source Verified Targeted |
Data type: Numeric How calculated: Counts items that have been source verified and have been selected for source verification. An item has been selected for source verification if one of the following is true:
