Rules
Rules report elements return information on rules in your study.
Report element |
Description |
Rule Item RefName |
Data type: String Description: The name that uniquely identifies the item to which the rule is attached in the study design code. This corresponds to the Short Question in the Central Designer application or Itemset Column Header in the InForm application. Access to this data can be restricted in the InForm application. When users who do not have access to this data run a report with this report element, the resulting report displays a series of asterisks (********) rather than the actual text. Data source: Replicated from the InForm transactional database to the Reporting and Analysis database. |
Rule RefName |
Data type: String Description: The name that uniquely identifies the rule in the study design code. This is the rule RefName. Data source: Replicated from the InForm transactional database to the Reporting and Analysis database. |
Rule Description |
Data type: String Description: Description of the rule. Data source: Replicated from the InForm transactional database to the Reporting and Analysis database. |
Rule Type |
Data type: String Description: The type of rule. Valid values are:
