I can't see any clinical data
A reserved word might have been incorrectly used in your study design. There are several reserved words that cannot be used for the following item properties in your study design:
- Short question.
- Default question or Question if a Short question is not provided, or is populated with a reserved word.
If a reserved word is used for the item Default question or Question, you must provide a Short question that is not a reserved word, or the clinical model in the Reporting and Analysis module fails to generate.
To fix this issue, you must remove reserved words from your study design in Central Designer and re-deploy the study. For a list of reserved words for reporting, see the Central Designer documentation.
