Use naming conventions to decide what to add to your report
The clinical data report elements that you can add to a Query Studio report are named in a way that can help you determine which report element to use. In general, the labels use the following convention:
optional prefix~ control identifier~ item identifier
The control identifier and item identifier are specified in the study design, retrieved by InForm, and populated in the Clinical Data by Forms folder in Query Studio.
Where the control identifier and item identifier come from
Report labeling
Label |
Description |
optional prefix |
The type of element:
control identifier |
Text that identifies the specific control for the item.
item reference |
Text that identifies the item as it appears in the study. The InForm application uses the following properties:
Default labels by control type
Keep the following in mind as you create a Report Studio report.
Default information for report elements
Report element (Default label) |
Description |
Default folder |
Code report elements |
[control identifier] Example: Cardiovascular ~ Cardiovascular |
Returns the text value that was entered during data entry. |
Basic Data |
Code~ [control identifier] Example: Code ~ Cardiovascular ~ Cardiovascular |
Returns the database code that corresponds to the value entered during data entry. |
Additional Data |
Data that require units of measure |
[control identifier] Example: Weight |
Returns the value that was entered during data entry. For instance, if the InForm user entered 135 on the form, the Weight element returns 135. |
Basic Data |
Unit~ [control identifier] Example: Unit~ Weight |
Returns the specific unit of measure that was selected at data entry. The label for this element has the prefix Unit ~. For example, the Unit ~ Weight element might return these values: kg or lbs. |
Basic Data |
Normalized~ [control identifier] Example: Normalized~ Weight |
Returns the normalized value; the InForm application converts measurements to the same, or normalized, unit of measure, based on a base unit of measure that is defined for your study. For example, if the base unit of measure is kilograms, the InForm application converts all entered values to kilograms and stores that value as a normalized value. |
Additional Data |
Unit Code~ [control identifier] Example: Unit Code ~Weight |
Returns the code value for the unit of measure, as it is stored in the database. The label for this element has the prefix Unit Code~. |
Additional Data |
Date controls |
Date ~ [control label] Example: Date~ Start Date |
Returns a date that includes Month, Day, and Year. If data is not entered, or is marked as Unknown in the InForm application, data does not appear for this report element. |
Basic Data |
Month Yr ~ [control label] Example: Month Yr ~ Start Date |
Returns a date that includes Month and Year. If data is not entered, or is marked as Unknown in the InForm application, data does not appear for this report element. |
Basic Data |
YYYYMMDD ~ [control label] Example: YYYMMDD ~ Date Started |
Returns a text string in YYYYMMDD format. Data displays here when a date control allows empty or unknown values. |
Basic Data |
Time ~ [control label] Example: Time ~ Date Taken |
Returns a standard time (24-hour clock) in HH:MM:SS format. If data is not entered, or is marked as Unknown in the InForm application, data does not appear for this report element. This report element appears only for those InForm controls that collect the time portion of a date. |
Basic Data |
HH24:MM:SS ~ [control label] Example: HH24:MM:SS~ Date Taken |
Returns a text value for time (24-hour clock). Data displays here when a date control allows empty or unknown values. This report element appears only for those InForm controls that collect the time portion of a date. |
Basic Data |
Year ~ [control label] Example: Year ~ Date Taken |
Returns only the year portion of a date. If data is not entered, or is marked as Unknown in the InForm application, data does not appear for this report element. |
Additional Data |
Month ~ [control label] Example: Month ~ Date Taken |
Returns only the Month portion of a date. If data is not entered, or is marked as Unknown in the InForm application, data does not appear for this report element. |
Additional Data |
Itemsets, repeating visits, and repeating forms |
Visit Index |
Returns a numeric value that identifies an instance of a repeating visit. |
Basic Data |
Form Index |
Returns a numeric value that identifies an instance of a repeating form. |
Basic Data |
Itemset Index |
Returns a numeric value that identifies an instance of an itemset. |
Basic Data |
Deleted itemsets and form instances |
Deleted form |
Indicates whether the reported form instance was marked for deletion in the InForm application. Use this report element with the Form Index element to see form instances that are deleted. Values are:
Basic Data |
Deleted itemset |
Indicates whether the reported Add Entry itemset was marked for deletion in the InForm application. Use this report element with the Itemset Index to see itemsets that are deleted. Values are:
Note: You cannot delete or undelete a Repeating Data itemset. |
Basic Data |
Incomplete data reasons |
Not Done ~ [item label] Example: Not Done ~ Unit Dose |
Returns a textual value that indicates why an item is marked Incomplete. |
Incomplete Data Reasons |
Blank~[item label] Example: Blank~HeartRate |
Indicates whether the reported item appears in a Repeating Data itemset, and is blank, as specified in the study design.
Transactional data |
CREATEDBYUSERID |
User ID of the user who started the form by entering data on the form or triggering a rule that entered data on the form. When the review schema is recreated, this column displays the system user ID. |
Basic Data |
CREATEDBYDATETIME |
Date and time when the reported form was started; that is, when a user entered data on the form or triggered a rule that entered data on the form. When the review schema is recreated, this column displays the date and time when the review schema was recreated. |
Basic Data |
MODIFIEDBYUSERID |
User ID of the user who started or modified the form by entering or modifying data or triggering a rule that entered or modified data on the form. When the review schema is recreated, this column displays the system user ID. |
Basic Data |
MODIFIEDBYDATETIME |
Date and time when the reported form was most recently started or modified; that is, when a user entered or modified data on the form or triggered a rule that entered or modified data on the form. When the review schema is recreated, this column displays the date and time when the review schema was recreated. |
Basic Data |
